Den STORE felg/dekk-vekt tråden
FELG DIM VEKT (kilde) + DEKK DIM VEKT (kilde) = TOT. VEKT (kilde)
Mazda NA '90-'93 7 spoke alloy 14x5.5 5,6kg (miata.net)+ 195/60-14 Sava Rapidex R2 ? = 13,6 kg (RonnyG)
Mazda NA '90-'93 7 spoke alloy 14x5.5 5,6kg (miata.net)+ 195/60-14 Cooper Cobra XST ? = 14,5 kg (RonnyG)
Mazda (BBS OEM) Alloy ('93 Black/Red) 14x6 3,9kg (miata.net) + ? = ?
Mazda '94-'97 7-spoke, hollow spokes 14x6 4,9kg (miata.net) + ? = ?
Mazda '94-'97 7-spoke, semi-hollow spokes 14x6 5,1kg (miata.net) + ? = ?
Mazda '94-'97 7-spoke, solid spokes 14x6 5,2kg (miata.net) + ? = ? Mazda '94 "M" 7-spoke polished 14x6 4,8kg (miata.net) + ? = ?
Mazda '95 M (BBS OEM) 15x6 5,5kg (miata.net) + ? = ?
Mazda Enkei 5-spoke alloy ('96 M, '97 STO) 15x6 6,6kg (miata.net) + ? = ?
Mazda '97 6-spoke polished alloy ('97 M) 15x6 6,6kg (miata.net) + ? = ?
Mazda'99+ 5-spoke alloy 14x6 5,8kg (miata.net) + ? = ?
Mazda'99-2002 Sport 5-spoke alloy 15x6 6,0kg (miata.net) + ? = ?
Mazda 99 10th Anniversary polished alloy 15x6 6,0kg (miata.net) + ? = ?
Mazda 2000 SE polished alloy 15x6 6,0kg (miata.net) + ? = ?
Mazda 01-'03 5-spoke alloy 16x6.5 7,0kg (miata.net) + ? = ?
Mazda 2001 SE 16X6.5 7,0kg (miata.net) + ? = ?
Mazda 2002 SE 16X 6.5 8,2kg (miata.net) + ? = ?
Mazda 2003 SE 16X 6.5 7,4kg (miata.net) + ? = ?
949Racing 6UL (Spec Miata) 15X7" - 13.1 lb. - 5.94 kg. (949Racing.com)
949Racing 6UL 15X7" - 11.9 lb. - 5.4 kg. (949Racing.com)
949Racing 6UL 15X7.5" - 12.1 lb. - 5.49 kg. (949Racing.com)
949Racing 6UL 15X8" - 12.8 lb. - 5.8 kg. (949Racing.com)
949Racing 6UL 15X9" - 13.4 lb. - 6.08 kg. (949Racing.com)
ATS DTC COMP LIGHT 15x8 6,3kg(Good-Win-Racing) + ? = ?
BBS RG-F 15*7 4,6kg (Tirerack)
BBS RG-F 16*7 5,8kg (Tirerack)
Enkei RP-F1-15x7 4,5kg(Good-Win-Racing) + ? = ?
Enkei RP-F1-16x7 5,9kg(Good-Win-Racing) + ? = ?
Enkei RP-F1-16x8 6,7kg(Good-Win-Racing) + ? = ?
Enkei RP-F1 17x7 6,7kg (Good-Win-Racing) + ? = ?
Enkei RPO2-J 15x7 5,9kg(Good-Win-Racing) + ? = ?
Konig Brite-Lite 15x6,5 5,5kg (Good-Win-Racing) + ? = ?
Konig FeatherLite 15x6,5 5,6kg (Good-Win-Racing) + ? = ?
Konig FeatherLite 16x7 6,8kg (Good-Win-Racing) + ? = ?
Konig Hurrry 15x6,5 6,2kg(Good-Win-Racing) + ? = ?
Konig Helium 15x6,5 5,2kg (Good-Win-Racing) + ? = ?
Konig Helium 16x7 7,0kg (Good-Win-Racing) + ? = ?
Konig Minuz 15x6.5 5,2kg (Good-Win-Racing) + ? = ?
Kosei K1 TS 15x7 5,8kg (tirerack) + ? = ?
Kosei K1 TS 17x7 6,4kg (tirerack) + ? = ?
Kosei K3 17x7 7,8kg(tirerack) + = ?
Motegi Track Tracklite 15x6,5 4,5kg (tirerack) + ? = ?
Motegi Track Tracklite 15x7 5,0kg (tirerack) + ? = ?
Motegi Track Tracklite 17x7 6,4kg (tirerack) + ? = ?
Motegi Track Tracklite2 15x7 4,5kg (tirerack) + ? = ?
Nippon Racing Zen 15X5,5 6,1kg (Good-Win-Racing) + ? = ?
Nippon Racing F2 15x6,5 5,5kg
OZ Ultraleggera 15x7 5,5kg(tirerack) + Khumo SPT 195/50-15 ?kg = 14,1 kg (Flyin Miata)
OZ Ultraleggera 16x7 ? + ? = ?
OZ Ultraleggera 17x7 7,3kg (tirerack) + Khumo SPT 205/40-17 ?kg = 16,4 kg (Flyin Miata)
Panasport 14x6 6,4kg (Good-Win-Racing) + ? = ?
Pro Race One 6,0kg-6,2kg (avh. av offset, Good-Win-Racing) + ? = ?
Pro Race II 15x7 6,4kg(Good-Win-Racing) + ? = ?
Rota Black Slipstreams 15x7.5 6,0kg (Good-Win-Racing) + ? = ?
SSR Competition 16x6,5 5,0kg (tirerack)
SSR Type C 15x6 4,0kg (Tirerack) + ? = ?
SSR Type C 16x6,5 5,0kg (Tirerack) + ? = ?
SSR Type C 16x7 5,5kg (Tirerack) + ? = ?
SSR Type C-RS 17x7,5 6,6kg (Tirerack) + ? = ?
Team Dynamics Pro Race 14x7 5,5kg(Good-Win-Racing) + ? = ?
Volk Racing TE37 15x7 4,5kg (tirerack) + ? = ?
Volk Racing TE37 16x7 5,5kg (tirerack) + ? = ?
Volk Racing TE37 17x7,5 7,3kg (tirerack) + ? = ?
Rangering felger etter vekt (5 letteste):
15x6
15x6,5
Nippon Racing F2 15x6,5 5,5kg (Good-Win-Racing)
15x7
Enkei RP-F1-15x7 4,5kg(Good-Win-Racing) 4,3kg (tirerack)
15x7,5
15x8
15x9
16x7
16x8
17x7
17x7,5
Postet linktips fra BAE:
"Forøvrig en gærning som har en egen hjemmeside på felgvekter:
http://www.wheelweights.net/
Her kan du sortere på vekt, dim og merke"
Dekk/felg-kalkulatorer:
http://www.miata.net/garage/tirecalc.html
http://www.1010tires.com/TireSizeCalcul ... ion=submit
Vei dine felger og dekk og post i denne tråden!!!
15x6
15x6,5
15x7
15x7,5
15x8
15x9
16x7
16x8
17x7
17x7,5
Rangering dekk etter vekt:
185/60/14
Toyo Proxes RA1 9,1kg
195/50/15
Toyo Proxes FZ4 7,7kg (miata.net)
Toyo Proxes T1R 7,7 kg (www.toyo.com)
Yokohama Advan A038R 8,6 kg (tirerack)
Goodyear Eagle F1 GDS3 8,6 kg (19 lbs) (uggla)
205/50/15
Hoosier Radial Wet 7,7 kg (tirerack)
Toyo Proxes T1R 8,2 kg (www.toyo.com)
Kumho ECSTA V710 8,2 kg (tirerack)
Hoosier A6 8,2 kg (tirerack)
BFGoodrich g-Force R1 8,2 kg (tirerack)
Michelin Pilot Sport Cup 8,2 kg (tirerack)
Hoosier R6 8,6 kg (tirerack)
Kumho ECSTA MX 8,6 kg (tirerack)
Kumho ECSTA SPT 9,1 kg (tirerack)
Yokohama Advan A048 9,1 kg (tirerack)
AVON Tech RA 10,4 kg (tirerack)
205/40/16
Toyo Proxes FZ4 8,6kg (miata.net)
205/45/16
Toyo Proxes FZ4 10,0kg (miata.net)
Toyo Proxes T1R 8,6 kg (www.toyo.com)
215/40/16
Toyo Proxes T1R 8.2 kg (www.toyo.com)
225/40/16
205/40/17
215/40/17
Toyo Proxes T1R 9,5 kg (www.toyo.com)
185/60/14
195/50/15
205/50/15
205/40/16
205/45/16
215/40/16
225/40/16
205/40/17
215/40/17
Har savnet en god oversikt over vekt for felger og dekk. Skal kjøpe nye felger men ønsker at den ufjærete vekten er så lav som mulig da dette har MYE og si for prestasjonen på en original mx-5. Starter derfor en tråd som har til hensikt å bli utvidet etter hvert med flere felgtyper (og dekk) slik at man forhåpentligvis slipper å lete nettet rundt etter svar på vekt for felger og dekk. Da produsentenes opplysninger må tas med en "klype salt" ønskes det helst målinger foretatt av pålitelige kilder dvs. butikker eller helst privatpersoner/medlemmer som virkelig har veid dekkene/felgende. Håper derfor at dere tar dere bryet med å veie dekk og felger og poste resultatet i denne tråden. Skal prøve å oppdatere første post fortløpende.
- DrHolm
- Medlemsnummer: 554
utrolig bra tråd!
gjøre til sticky moderator??
hva med vekta av org. felg, med dekk?
Vekt på original felger: http://www.miata.net/faq/wheel_weights.html
Vekt på dekk: http://www.miata.net/faq/tire_weights.html
1 pound = 0.45359237 kilogram
C a r t m a n
Medlemsnr: 544
Medlemsnr: 544
R-Dekk av ymse fabrikanter:
Hoosier A6 8,2 kg
Hoosier R6 8,6 kg
Yokohama Advan A038R 8,6 kg(195/50-15)
Alt iht http://www.tirerack.com
Alle dim i 205/50-15, bortsett fra de som åpenbart er av en annen dim.
Jeg brukte den dim'en da den var tilgjengelig på flest dekk, og at jeg bruker den selv.
Hoosier er det desidert beste dekket, men slites også fortest ut.
Hoosier A6 8,2 kg
Hoosier R6 8,6 kg
C a r t m a n
Medlemsnr: 544
Medlemsnr: 544
Data på Toyo Proxes T1R iht. www.toyo.com:
195/50/15: 7,7 kg (17 lbs)
205/50/15: 8,2 kg (18 lbs)
205/45/16: 8,6 kg (19 lbs)
215/40/16: 8.2 kg (18 lbs)
225/40/16: 8,6 kg (19 lbs)
205/40/17: 8,6 kg (19 lbs)
215/40/17: 9,5 kg (21 lbs)
Tror jeg har dekket de mest relevante dimensjoner.
13' Subaru BRZ
x - 10' Nissan GT-R
x - 08' BMW M3 Coupe
x - 06' Porsche 911 C2S
x - 04' Mazdaspeed, T. Grey
x - 93' Classic red
Medlemsnr: 563
x - 10' Nissan GT-R
x - 93' Classic red
Medlemsnr: 563
Litt dobbelt posting her. Er i skikkelig lette-hjul-modus.
Noen som vet om Enkei forhandles noe sted i Norge?
Har leita en del rundt på nettet uten å finne noe. Blir dyrt hvis man må importere japanske felger via USA.
Hadde egentlig bestemt meg for Ultraleggera, men den kiloen ekstra pr. felg kommer til å plage meg![Wink :wink:](./images/smilies/icon_wink.gif)
