Rammenummer - hva står det for?
Mener det var noen som hadde oppført dette i tråden sin. Hva betyr alle tallene og bokstavene i rammenummeret?
Og Rudolf:
Jeg var hos Mazda i dag, og de fortalte meg at jeg hadde en 1992 MX5, og at den var produsert på et helt annet sted enn Hiroshima. Hvordan kan de finne noe annet enn det programmet ditt fant? (Du har pastet inn infoen i tråden min, som blant annet sier at den er laget i februar 1993 i Hiroshima)
Og Rudolf:
Re: Rammenummer - hva står det for?
The typical Miata VIN number looks something like this:
JM1NA3522L0100014
* The J is Japan
o 1 = MI, US
o 4 = KY, US
* M refers to Mazda Japan
o Y = AAI (Mazda USA)
o F = Ford
* The 1 designates vehicle type ie: car
o 1=car
o 2=truck/van
o 3=van
o 4=truck
o V=car [US]
* The NA is the model ID
o NA=Gen 1 Miata
o NB=Gen 2 Miata
o NC=Gen 3 Miata
o UF=B-2200
o SD=MX-6
o FC=RX-7. etc...)
* The 35 is the body style
o Body style codes:
+ Cars:
# 22=4 door sedan
# 23=3 door hatchback
# 24=5 door hatchback
# 31=2 door coupe
# 33=2 door coupe
# 35=convertible
# 41=2 door
# 43=2 door coupe
# 46=4 door sedan
# 52=Wagon (used in GLC)
# 62=Wagon (used in 323)
+ Trucks:
# 11=short bed (carb)
# 12=short bed (pre-1986)
# 13=B-series
# 16=B-Series
# 17=B-series
# 21=long bed (carb)
# 22=long bed (pre-1986)
# 31=cab plus
# 32=cab plus (EGI)
# 41=short bed (4x4)
# 42=2 door (4x2)
# 44=2 door (4x4)
# 51=long bed (4x4)
# 61=cab plus (4x4)
+ MPV:
# 52=4 door wagon (4x2 & 4x4)
# 62=4 door van
# 28=4 door van (FF)
* The 2 may be engine code. We're not certain.
* The 2 is a check digit
* The L is model year (L=`90, M=91, N=92, P=93, etc...)
* The 0 is the plant number (0=Hiroshima, 1=Hofu)
o 1=Hofu
o 5=Flat Rock
o T=Edison
* The 100014 is the car number, reset to 100000 and the first car of that year will be 100001.
http://www.hazmat.com/~mjb/candm/decoder/
JM1NA3522L0100014
* The J is Japan
o 1 = MI, US
o 4 = KY, US
o F = Ford
o 1=car
o 2=truck/van
o 3=van
o 4=truck
o V=car [US]
o NA=Gen 1 Miata
o NB=Gen 2 Miata
o NC=Gen 3 Miata
o UF=B-2200
o SD=MX-6
o FC=RX-7. etc...)
o Body style codes:
+ Cars:
# 22=4 door sedan
# 31=2 door coupe
# 33=2 door coupe
# 35=convertible
# 41=2 door
# 43=2 door coupe
# 46=4 door sedan
+ Trucks:
# 13=B-series
# 16=B-Series
# 17=B-series
# 31=cab plus
# 32=cab plus (EGI)
# 42=2 door (4x2)
# 44=2 door (4x4)
# 51=long bed (4x4)
# 61=cab plus (4x4)
+ MPV:
# 62=4 door van
o 1=Hofu
o 5=Flat Rock
o T=Edison
Det der er MIATA.nope-mx5 wrote:The typical Miata VIN number looks something like this:
JM1NA3522L0100014
LoKi har en Europeisk MX5
LoKi wrote:Mener det var noen som hadde oppført dette i tråden sin. Hva betyr alle tallene og bokstavene i rammenummeret?
Og Rudolf:
Dette er bilen din og dataene er fra Mazda sin egen database over Europeiske biler.
Du har en "1992 modell" men den er produsert 3. februar 1993.
(Kan hende at de har trodd du har en "import" og sjekket deg mot amerikansk database
Du kan jo sjekke selv om rammenummer stemmer (hender at det sniker seg inn en feil vettu ...)
Her er en generell VIN-dekoder for Europeiske biler:
- biXen
- Medlemsnummer: 999
Hofu er btw Mazda sin andre større fabrikk, brukes nok mest til de større bilene deres som pickupene, varebilene og div. men blir nok brukt også til å ta unna fabrikasjon når det gikk mye av visse modeller. Min er også fra Hofu noe rimer med at det ble lagd ekstremt mange 8ere i 2004, hovedsaklig skulle de alle "egentlig" blitt lagd i Hiroshima.
Ahh, da er det Mazda Norge som stuker siden den kommer opp som en 1992 hos dem.
Det som er rart er jo at den er registrert som en 1993 på vognkortet..
Anywho, det du har lagt inn er korrekt, Erik. Da er det bare Hiroshima som var en liten lesefeil
Takk for hjelpen!
Takk for hjelpen!
Hvorfor er det rart at den er registrert i 1993 ?LoKi wrote:Ahh, da er det Mazda Norge som stuker siden den kommer opp som en 1992 hos dem.
Den er jo produsert i februar 1993.
Hofu ble brukt til produksjon av et fåtall MX5/Miata/Eunos under produksjonstoppene i 1990-93.biXen wrote:Hofu er btw Mazda sin andre større fabrikk, brukes nok mest til de større bilene deres som pickupene, varebilene og div. men blir nok brukt også til å ta unna fabrikasjon når det gikk mye av visse modeller. Min er også fra Hofu noe rimer med at det ble lagd ekstremt mange 8ere i 2004, hovedsaklig skulle de alle "egentlig" blitt lagd i Hiroshima.
Leopold er produsert i Hofu.
Re:
De henter vel årsmodell-info fra Mazda? Mazda Norge sier det er en 1992, og går dermed ut i fra at den er laget i 1992. Dette var infoen jeg fikk i dag på Ullern bil.Rudolf wrote:Hvorfor er det rart at den er registrert i 1993 ?LoKi wrote:Ahh, da er det Mazda Norge som stuker siden den kommer opp som en 1992 hos dem.
Jeg tror du blander sammen litt.LoKi wrote: De henter vel årsmodell-info fra Mazda? Mazda Norge sier det er en 1992, og går dermed ut i fra at den er laget i 1992. Dette var infoen jeg fikk i dag på Ullern bil.
Ullern Bil er et bilverksted (som sitter med sine mikrofilmer og blander sammen "import"-biler og "norsk").
Hvis de har lest feil på Hiroshima og Hofu så kan det stemme med at de blander sammen MX5 og Miata.
Mazda Motor Norge er importøren og de har relativt god peiling, men det virker ikke som det er dem du har vært i kontakt med.
1992 modell betyr at bilen har karrosseri og utstyr i følge 92 modell-varianten.
En bil produsert (og registrert) i 1993 kan godt være en 1992 modell etter Mazda sin modell definisjon.
Se på skjermbildet som jeg la ut og les det som står der.
Du sa i tråden min at den var laget i Hiroshima, ergo var lesefeilen jeg refererte til din når du pastet dette til meg for lenge siden
Han sjekket i databasen dems hva info de hadde om bilen, og fikk opp at det var en 1992.
Det jeg forstår det som da, er at databasen til de offisielle forhandlerene av Mazda sier at bilen er en 1992-modell.
Grunnen til at dette ble tatt opp, er fordi han sa bilen var forskjellig fra 92-93.
Jeg bare regnet med at offisielle Mazdaforhandlere brukte samme data som importøren, siden de tross alt skal snakke om samme rammenummer. At de sitter med diffrensierende informasjon om en bil virker direkte amatørmessig.
Skjermbildet har blitt lest mange ganger, og det er nettopp derfor jeg reagerer på at jeg får annen informasjon når Ullern bil slår opp chassisnummeret mitt.
Det med 1992-modell kontra produksjonsår 1993 har jeg forsøkt å forklare deg ..
F.eks. Rudolf som er produsert i 1990 står oppført i den samme databasen som en 1989-modell.
- perri
- Medlemsnummer: 858
Re:
Hva får du ut av sette da, jmzna18c200309357 , gjerne historikken og det hele !Rudolf wrote:Det med 1992-modell kontra produksjonsår 1993 har jeg forsøkt å forklare deg ..
97 NA RØD 1,8L BP
06 SAAB 93 SC Maptun stg.1
97 NA RØD 1,8L BP
Re:
Ja, jeg forstår det.Rudolf wrote:Det med 1992-modell kontra produksjonsår 1993 har jeg forsøkt å forklare deg ..
Men Mazda sier den er laget i 1992 OG er en 1992-modell.
Ergo.
Jeg synes det er rart at Mazda sitter med 2 informasjonskilder i Norge.
- biXen
Men sier de det utfra at de har lest en produksjonsdato som sier bilen er laget i 1992, eller antar de den er laget i 1992 pga. det er en 92 modell? I motsetning til idag så var jo ikke modellåret forover i tid den gang.
Hakke snøring.biXen wrote:Men sier de det utfra at de har lest en produksjonsdato som sier bilen er laget i 1992, eller antar de den er laget i 1992 pga. det er en 92 modell? I motsetning til idag så var jo ikke modellåret forover i tid den gang.
Det tyder jo på at det var en assumption av han, siden den er en 1992-modell. Virker som hans oppslagsverk kun tar utgangspunkt i hva rammenummeret sier, ikke hva databasen sier om dette rammenummeret.
Nivået av uvitenhet jeg har møtt på fra instansene jeg har vært borti de siste dagene er helt forferdelig.
Jeg er rett og slett LAMSLÅTT!
