GOD JUL!
Posted: 19 Dec 2004, 21:03
http://img.photobucket.com/albums/v494/ ... let001.jpg
God Jul fra Røde Rudolf og hans tre hjelpere fra Jessheim
Fiin bil, Pelle!!HansBRG98 wrote:God Jul..
Good news! Your order from Flyin' Miata has been shipped. If you requested
UPS as the shipping method, you can follow its progress through the
following link:
http://www.flyinmiata.com/us/track.php? ... =blablabla
Item Qty Qty Qty
Expected
Number Description Ord. Shp. Bck. By
07-16500 Link ECU, keypad & temp sensor 1.00 1.00 0.00
1994-95 1994-95
Mazda MX-5
07-47010 Serial Link with USB adapter 1.00 1.00 0.00
04-41000 Injectors, 550cc, Set of 4 1.00 1.00 0.00
BALLAST with ballast resistors
07-77000 Data Log Lab, 1990-97 1.00 1.00 0.00
FULL MiataLink full version
07-26500 Boost Control Solenoid 1.00 1.00 0.00
1990-97 1990-97
13-97907 Bushing, swaybar end link 2.00 2.00 0.00
1 per each end of car (F or R)
13-97000 Suspension Bushings-non adjust 1.00 1.00 0.00
04-56200 NGK Extended Reach Spark Plugs 1.00 1.00 0.00
Heat #7, set of 4
07-36500 Link knock sensor & mount 1.00 1.00 0.00
1994-97 1994-97
36-50020 Hose Barb, M, 3/8NPT 5/8" Hose 1.00 1.00 0.00
(oil drain T28 turbo)
36-40230 HOSE, OIL, 5/8" PER INCH 20.00 20.00 0.00
(oil drain line)
36-70105 HOSE CLAMP, Winzer, 15-24mm 2.00 2.00 0.00
(oil drain hose)
35-46000 Drill Bit, 14.5mm (37/64") 1.00 1.00 0.00
(for oil drain/return)
35-46500 Tap, 3/8NPT 1.00 1.00 0.00
(for oil drain)
additional order confirmed via
The total amount of your order, including shipping, is a shitload of money...
Det var usedvanlig trist! Håper den blir bra igjen om ikke altfor lenge!JohnBGoode wrote:God Jul........................................ For min egen del ser jula ut til å ha sine tunge stunder. Det ser ut til at jeg tok livet av tyttebæra på lille julaften...... Baklengs i 80 setter sine spor kan man si..... Krattskogen har aldri vært så glissen langs riksveg 312. Når veivesenet i tillegg setter ut uønskede skilt med alskens unyttig informasjon langsetter vegen, blir det fort store rynker å rette ut. Men jula kommer okkesom..................ha en god en folkens
