SPS Motorsport
Kun firma kan lage nye tråder her, og det skal kun være MX-5 relatert!
Guido@SPS
Registrert: 13 apr 2019, 11:42
Re: SPS Motorsport
Legg inn av Guido@SPS »
Hello Stalfa,
the easiest way would be to make an inquiry with all the modifications/work You want via email and we can make an offer.
This is a very individual built, so it depends on Your personal needs.
Best regards
Guido from SPS
Guido@SPS
Re: SPS Motorsport
And again a really nice ND. This time we installed BBR GTi camshafts with a full exhaust system and tuned the ECU on the dyno. Now car the has 200hp at the flywheel instead of 160hp.
The car also got some nice 17" Rotas, our SPS street coilover setup and Recaro pole position in full leather.
Best regards
Guido from SPS
Guido@SPS
Re: SPS Motorsport
This Turbo NA is a more powerful version. A 1.8L BP with forged internals, a Garrett GT3071R turbocharger producing 320hp at the flywheel with 1.2 bar boost.
Some more specs:
Competition Clutch Stage 4
K-Sport coilover setup
StopTech Big Brake Kit
CAE short shifter on a 6-speed gearbox
Reroute Kit
Recaro Profi SPG seats
sparco seat harness
Nardi steering wheel
Rota Grids in 8x15 with 25mm offset
full 3" custom exhaust
Best regards
Guido from SPS
Guido@SPS
Re: SPS Motorsport
Hey guys,
we have a special offer for You.
We sell our TD04-Turbokit for the MX-5/Miata NA, NB and NBFL for just 3499€.
On the stock 1.6L You get 220hp at the flywheel, on the stock 1.8L You get 250hp at the flywheel.
The kit contains:
Kraken cast iron manifold
Two-piece downpipe (first part made of cast iron, second part made of stainless steel)
Turbocharger incl. Matching connection accessories
Steelflex oil feed pipe
water pipe
High temperature oil return
Giselwerks Hardpipe boost pressure piping
efficient intercooler
Open air filter
SPS Motorsport 700CC Injectors (calibrated and tested)
Engine control unit with matching basemap
mounting material (incl. spark plugs BKR7EIX and modified washer fluid reservoir)
https://www.youtube.com/watch?v=v18XYMgpjmU&t=0s
https://sps-motorsportshop.com/shop/en/ ... 98-SPECIAL
Best regards
Guido from SPS
Registrert: 03 jan 2013, 22:24
Re: SPS Motorsport
Legg inn av MX-Jon »
I think this is also very important to many of us: In addition to this offer, we can offer you the TÜV approval of the turbo kit for only 350 euro
Porsche 911 1991 (964 Carrera 2 coupe)
