Bra noen startet en tråd om gateslicks.
Har titta litt rundt på tirerack, og her er litt ymse av hva jeg fant:
Dekk str. 205/50-15
sammenlikning av div. gateslicks, men dem har ikke Toyo desverre..
TEST av BFGoodrich g-Force R1 og Hoosier Racing Tyre R6
"The g-Force R1 radials were ordered from BFGoodrich's distribution center and compared to Hoosier Racing R6 Sports Car D.O.T. Radial tires that BFGoodrich ordered from The Tire Rack. Tread shaving wasn't required because both tires are molded with approximately 4/32" of original tread depth. None of the tires were heat cycled before the test and, in order to emulate typical track sessions, multiple lap stints were driven to bring tires up to temperature and then challenge the tires' consistency as they ran successive laps.
While the Hoosier R6 tires provided the expected responsiveness and grip, the BFGoodrich g-Force R1 radials provided quicker response and higher levels of grip, as well as more consistency lap after lap. Additionally, the g-Force R1 radials were more responsive to begin with, as they immediately began to carve through the transitions of the left-right-left s-turn and into the steady-state corners. This combination of characteristics allowed the drivers to run the g-Force R1 radials with greater confidence, reduced the variations in lap times and resulted in lap times that averaged just over one second faster than the Hoosier R6 tires on the approximate 45-second, nine-turn course. While the number of laps run didn't wear out any of the tires, the BFGoodrich g-Force R1 radials appeared to have less treadwear as well.
Obviously our introductory experience didn't allow us to explore every combination of vehicle preparation, suspension adjustment or inflation pressure, however it did show that the BFGoodrich g-Force R1 radials combine the predictability and consistency under these circumstances that's ideal for beginning drivers, as well as the responsiveness and speed desired by experienced racers. We consider the BFGoodrich g-Force R1 radials to be worthy of consideration for every driver participating in track day, time attack and racing events."
"Hard Core" gateslicks:
Kumho Ecsta V710 Viser seg å være det mykeste dekket, og får best tilbakemeldinger fra kunder med dim. rundt 17-18" kommer og best ut blandt AutoX fantaster.
Hoosier A6 Er hakk i hel på Kumho dekket, når det gjelder grep. Viser da også til tilbakemeldingene fra AutoX fantaster, med noe tyngre skytts enn våre biler.
BFGoodrich g-Force R1 Tar litt lengre tid å få varme enn Kumho dekket over. Men til gjengjeld holder de noe lengre.
Hoosier R6 Er et dekk kundene på TireRack skryter opp i skyene, når det gjelder bane kjøring. Er nok i hardeste laget ved AutoX.
Disse fire dekkene ville jeg nok latt bli på banen, til de som er ute etter mer sikkerhet og max grep der. Men det forutsetter et gjevnt underlag og noen plussgrader..
EDIT: kan lønne seg å spandere på seg "heat cycling" noe som vist forbedrer levetiden..
