Vibrerende speedometer-nål
- Gabzh
- Medlemsnummer: 1282
Mellom 0 og 55 så vibrerer nåla i speedometeret en god del (se video). Mellom 55-65 så demper det seg veldig og er borte etter 65. Hva skyldes dette? På tide å bytte ut instrumentpanel?
[youtube]CUfchKaRHXA[/youtube]
- Trouble
- Medlemsnummer: 1288
Re: Vibrerende speedometer-nål
Kommer det lyd derifra også? Har samme problem som deg, og for meg er det nok en ny speedo-kabel som trengs.
Prøv å bare smøre kabelen. Koble fra bak speedometeret og hell litt olje ned med en oljekanne. Kan hende det løser problemet så sparer du litt knotejobb. Ellers likte jeg løsningsforslaget til Ørnbjørn
- Ørnbjørn
- Medlemsnummer: 967
Olje skal ein vel være forsiktig med? Ref. miata.net.
Question: Has anyone else out there had problems with the speedometer making noise? I have this problem only on cold mornings when she has been sitting all night. It only makes the noise when I get above about 40 MPH - no noise at the slower speeds. It only happens in the winter and only in the morning when it's the coldest. The noise is the of the sort that sounds like a cable rubbing against something. I don't know if the speedometer uses a metal cable or not, but that's what I think it is.
A:
Just like a motorcycle control cable, the speedometer cable may need some lubrication occasionally. Per the directions in the shop manual, remove the instrument module containing the speed/tach/etc. Very gently roll the module towards the steering wheel to expose the speedo cable's white plastic connection to the back of the speedo head itself. Depress the small release tab and remove the cable from the speedo.
Use a commercial product made for the motorcycle market called Dri-Slide. This is a graphite-molybdenum disulfide compound that goes on wet and then the liquid vehicle dries up to leave a non-sticky, very slick DRY lubricant on the cable. DO NOT use oil !! The Dri-Slide container uses a long, thin "hypodermic-style" wand to allow you to accurately direct the material into the correct location. Be careful not to catch the end of the wand on anything and spring it back. The resulting "twang" will spray black lubricant all over everything !!! The resulting stains will be permanent.
A:
Oki, jeg trekker meg tilbake til arbeidet og heller gjør ting jeg kan
Har tydeligvis hatt flaks tidligere..... Her er grunnen:
It will almost certainly be wound up by the rotating inner shaft, acting as a screw, and forced into the instrument,
- Medlemsnummer: 982
Kan det vera at speedokabelen er litt laus i kobling mot girkasse?
2019' MX5 Grå 2.0L Sport
1990' 323 GTX
X 1991' MX5 BRG 1.8 VVT
1990' 323 GTX
Har hatt stort hell med både olje og med slik hvit grease på sprayboks ifra biltema, men klart det er nok best å bytte waiern når dette skjer,,
- Lloyd
- Medlemsnummer: 912
Alt er relativt! Du må løsne den fra girkassen, under bilen, ca midt på.
Løsne noen klips den henger i på vei mot motoren og løsne den fra torpedovegg gjennomgangen.
Tror noen klarer og løsne den av speedoen med og krype hode først ned mot pedalene. Eg er for stor for den løsningen, og syntest det var lettest og ta av speedometeret ovenfra.
- josiene
- Medlemsnummer: 1119
Har vært borti tilfeller der det hjalp å snu/vri strømpen ved å løsne mutteren på gearkassa (på speedometersiden går det vel av seg selv) og vri den omtrent 90 grader. Grunnen er at innerkabelen over tid sliter et spor i strømpen der den har størst bøy. Litt olje i tillegg til dette gjør heller ikke noe.
My 2 cents.
Jostein
My 2 cents.
Jostein
