~You have to explain to people that the car's faster if they're not in it, and then dodge the slap and accusations that you're calling them fat.
~You've spun out at least once, then quickly got going again, purposely spun 180 degrees the other way, and continued on as if you meant to spin the first time, only now your heart is about ready to explode because it's beating so damn fast.
~People insist it's FWD, you promptly prove them otherwise, and they get reeeeal quiet.
~You have to explain that your car is faster in turns than going straight.
~You think a 1.8 is a large displacement motor.
~You regularly use acronyms like AFM, CAS, NA, OTM, OPG, and YMMV.
~You know what HLA noise is.
~You get out the car when at a drive-through ATM.
~You find yourself driving much later into dusk before turning on your headlights to keep the aerodynamics clean.
~People have to ask you what kind of car you have--after you walk them around it.
~It's quicker to turn the engine back on to roll up the power windows, especially when cold.
~After buying your NA, you spend more time on Miata.net than you ever used to spend watching tv.
~You shop for rims and tires by weight.
~You know what it means to "add lightness".
~200-300hp is BIG horsepower.
~Your significant other understands that this is the other woman and still marries you.
~The only floor jack that fits is an expensive race jack.
~You repeatedly “searchâ€
You know you're an Miata owner when...
94 1.8 (Prosjekt)
15 BMW i3 - Batterirakett
07 Honda CR-V - Konebil
x 98 1.8 JR Supercharged
x 91brg
x 91brg
- _mx5_Rune_
- Medlemsnummer: 542
hehe, hørtes kjent ut mye av det her ja..
- 12 mod i40 premium
medlem nr 542
medlem nr 542
HAHA!! Vanvittig bra!
Føler meg nesten som del av AA eller no. - kjenner igjen ALLE Mx-5 eier-tegnene. (bortsett kanskje fra bil-minibanken;de har vi ikke så mange av her i Norge...)
Alt fra jentenes reaksjon på å ikke skjønne hva slags bil det er, selv etter å ha sittet i den et par ganger, til førstereaksjonen til gutta (som vanligvis er latter og sjikane) som alle senere vil kjøre den.
Og selv måtte jeg jo bare sette en check ved alle de andre symptomene.
Morsomt at vi alle er hekta.
