P0402
P0402 OBD-II Trouble Code
Technical Description
Exhaust Gas Recirculation Flow (EGR) Excessive Detected
What does that mean?
EGR stands for Exhaust Gas Recirculation. It is part of the vehicle emmissions system, and is used to reduce combustion temperature and pressure to control Oxides of Nitrogen. There are generally three parts to the EGR system: the EGR valve, an actuator solenoid, and a differential pressure sensor (DPF). These things work together to deliver the correct amount of recirculation based on engine temperature, load, etc. The P0402 code means that OBD detected an excessive amount of EGR.
Page copy protected against web site content infringement by Copyscape
Symptoms
You may notice drivability problems such as the engine may surge off idle. There may also be other symptoms.
Causes
A code P0402 most likely means one or more of the following has happened:
* The DPFE (differential pressure) sensor is faulty and needs to be replaced
* There is a blockage in the EGR (most likely carbon buildup)
* The EGR valve is faulty
* The EGR valve may not be opening due to a lack of vaccuum
Possible Solutions
With a P0402, it is common for people to replace the EGR valve, only to have the problem return. The most likely solution is to replace the DPFE sensor.
* Check the voltage at the DPFE sensor both at idle and when the EGR is open
* Replace the DPFE sensor
Coil til Mazdaspeed
Fått tips på MSM forumet om å rengjøre EGR ventilen. Prøver det først.
En fin "how-to" på linken:
http://www.mazda-speed.com/forum2/index ... 742.0.html
13' Subaru BRZ
x - 10' Nissan GT-R
x - 08' BMW M3 Coupe
x - 06' Porsche 911 C2S
x - 04' Mazdaspeed, T. Grey
x - 93' Classic red
Medlemsnr: 563
x - 10' Nissan GT-R
x - 93' Classic red
Medlemsnr: 563
