olje på girkasse på rx7?!
Cadolfsen
Post by Cadolfsen »
noen som vet hvordan olje som skal være på girkassen på 3generasjon rx7.. ?
Nissan Primera 2.0
x Mazda Rx7
x Mazda mx5 386whp
x Subaru Impreza WRX
x Subaru Legacy 1.8
x Volvo S70 2.4
x Ford Escort 1.8TD
x Honda Civic 1.6VTI
x Ford Mondeo 1.8
x Volvo 240 2.3
x Ford Scorpio 2.8
Vegard
Medlemsnummer: 0
Post by Vegard »
The diff is easy the transmission is tricky. First I went to Home Depot and got 8 Ft of 5/8th od dia clear tubing and a plastic funnel set. That's how you get the oil in the transmission and differential. Now, make sure you have 3 new aluminum washers for the large transmission drain plug, the differential fill plug and differential drain plug before you start. I get mine from the dealer. I don't like using the copper ones that the parts stores usually carry because, at least here at the beach, galvanic corrosion (from dissimilar metals) can be a problem. Make sure you have a tube of liquid Teflon thread sealant for the small transmission drain plug and the transmission fill plug (also at Home Depot, or you can get the fancy automotive stuff at the parts store). You also need a few large metric combination wrenches and sockets I can't remember the exact sizes but I think they were ~22-25mm. Finally you need 3 quarts of oil for the transmission and 2 quarts for the differential. I used Redline MTL for the tranny and Redline 75-W90 for the diff.
The differential is easy the plugs are in the back, undo the fill plug then undo the drain plug. Put the new washers on the plugs, and put the drain back in. Stuff one end of the hose into the differential fill hole, push the funnel onto the other end of the hose. Stand up next to the rear of the car while holding the funnel. Slowly pour in the oil until it just begins to spill out of the fill hole. As a side note, the car should be completely level while doing all filling operations.
Now for the transmission, there are two drain plugs, one fill plug and one plug that you don't touch. First remove the sheet aluminum cover and set it aside. On the bottom of the transmission case is an obvious big drain plug. The other three plugs are on the driver's side of the transmission. The highest one has a recessed square socket don't touch it. Approximately below it is a plug with a protruding square socket, this is the fill plug. Behind and a little below the fill plug is another protruding square socket plug, this is the second drain plug. Remove the fill plug then the big drain plug let the oil run out. Then remove the second drain plug. You remove the fill plug first other wise the oil "plops" out everywhere except in your drain pan (you did remember to put a pan under the drain plug :).To fill the trans put the new washer on the big drain plug and the sealant on the second drain plug and put them back in. Stuff the funnel in one end of the hose and ~3" of the hose in the fill hole (it just barely fits) stand up next to the car while holding the funnel and slowly pour in the oil until it just starts to spill out.
Kilde: http://robrobinette.com/how_to_misc2.htm
Google er din venn, og hvis du vil finne ut av hva andre med 3. gen girkasse bruker kan du besøke: http://www.rx7club.com/forumdisplay.php?f=16
mrinzane
Post by mrinzane »
Overføring, manuell 5/1 Smøringshette 2,5 liter
Brukstype: Normal
Sjekk/skift:
Sjekk 40000 km / 24 måneder
Bytt 80000 km / 48 måneder
SAF-XO 75W-90
TAF-X 75W-90
SMX-S 75W-85
X Mazda MX-5 91brg.
X Mazda MX-5 92rød.
Fatboy
Medlemsnummer: 764
Post by Fatboy »
Denne har vel de aller fleste biler, inklusive RX-7.
http://www.shell.com/home/page/nor/prod ... match.html
Cadolfsen
Post by Cadolfsen »
castrol har den dær saf-xo 75w90 er den til girkassen??
Nissan Primera 2.0
x Mazda Rx7
x Mazda mx5 386whp
x Subaru Legacy 1.8
x Volvo S70 2.4
x Ford Escort 1.8TD
x Ford Mondeo 1.8
x Volvo 240 2.3
x Ford Scorpio 2.8
