Forskjellige differ
glaibilenmin
Medlemsnummer: 413
Forskjellige differ
Post by glaibilenmin »
Noen her på dette store gode forum som kan fortelle meg hva som er best av en viskose diff og en lamell diff???
Silverboy
Post by Silverboy »
Fant dette:
Types
Two main types of LSD have been generally used - mechanical (geared or clutch-based) and fluid based (viscous). The latter is gaining ground especially in modern all-wheel drive vehicles, and generally require less maintenance than the mechanical type.
Mechanical
In the mechanical clutch type, differential velocity is detected by some means, such as a centrifugal weighted rotor, and this applies a force to a clutch mechanism which links the two shaft together to a varying extent - the greater the differential velocity, the more force is applied. This forms a negative feedback loop which limits the slip to a preset degree. In some designs, the clutch is self-actuating. Often, small multi-plate clutches are used. One disadvantage of the mechanical type is that the limiting action tends to occur quite rapidly rather than gradually, and this in itself can create unsettling dynamic effects for the vehicle as a whole.
Another type of mechanical LSD is the geared torque-sensing type. This arrangement uses planetary gears to "sense" torque on one shaft. The most famous version is the Torsen differential invented by Vernon Gleasman in 1958, then sold to Gleason Corporation, who started marketing it in 1982. But there are many other types available as well. Geared LSDs are less prone to wear than the clutch type, but their torque distribution characteristics can be less than ideal.
Viscous
The viscous type is generally simpler, and relies on the properties of a dilatant fluid - that is, one whose viscosity varies as the inverse proportion of an applied force. Silicon-based oils are often used. Here, a chamber of fluid rotates with the normal motion of the output shafts, but a differential motion causes paddles or vanes to move through the fluid. The greater the speed of the vanes, the more resistance the fluid will put up to oppose this motion. In contrast to the mechanical type, the limiting action is much softer and more proportional to the slip, so for the average driver is generally much easier to cope with.
Viscous LSDs are less efficient than mechanical types, that is, they "lose" some power. However, they are less prone to breakdown as long as the fluid is changed regularly.
-2001 MX5 1.8 Sport
-2019 BMW 320xd
-2014 BMW X1
x (- 89 BMW 327i 755whp)
