Er vist en Lexus 4,2l V8 etter det jeg har hørt...
".....This is no normal gruff and rough V8 rocking you from side to side, this is smooth, turbine smooth with 225 kilowatts in a 1180 kilogram svelte body just waiting to be unleashed. Through her torsionally rigid space frame chassis, the Roadster is complemented by fully adjustable coil-over suspension, sitting on ROH 17x8 alloys front, shod with 215/40 and 17x9 rears with 255/40. Impressed?..."
"......If you admirerd the Bullet Roadster, then the SS Roadster (Sprintex - Supercharged) is about to put you in seventh heaven, we are not just talking stunning, we are talking awesome power and handling, 1200 Kilograms propelled by our piste de resistance the 320 Kilowatt, with 575 Newton-meters of torque Bullet SS Engine. The SS starts life as the Roadster with an indestructible bottom end, forged cross-drilled crank and Six Bolt Mains, the SS then gets Forged Rods and Pistons, resulting in a Bottom End Bullet-Proof to 900+ Horse Power......."
Det er i Australia du finner disse lekkerbiskene....
www.bulletcars.com
Fikk tipset av en kompis som har studert i Australia over en lengre periode. Fikk også tips om å sjekke ut Mx5 SP. En utgave som kom kun for det Australske markedet.
"......The newly released MX-5 SP is bursting with an amazing 39 percent more power and 60 percent more torque than the standard MX-5; it's more than enough to transform the SP into a fully-fledged, drop-your-jaw rocketship."
