Noen som har erfaring med disse?
Jeg skal til å bestille masse deler, og husker at jeg har lest masse negtivt om et firma, men det var kanskje Buthe motorsport i Tyskland?
Jeg trenger også et bakvindu, dvs det svarte vinylen rundt og plastvinduet. Er det noe som Mazda leverer, eller bør jeg demontere det oppråtna bakvinduet mitt og gå til en salmaker? Resten av kalesjen min er veldig hel og fin. Skjønner ikke hvordan den bakre delen kan ha blitt så ødelagt i forhold til resten av taket.
Her er det jeg skal bestille fra sftmx5 i hvert fall:
(blir noen tusen men jeg ga jo bare 35k for bilen da...)
Air filter
we carry standard air filter for both MK1 & MK2
Price: £ 2.43 (MK1 .. 89-97 pop-up headlight model)
Fuel Filter
fits all MK1 (89-97) pop-up headlight model
Price: £ 7.50
Spark Plug Leads
Fits all models, yes there are cheaper leads on the market but we have found these to be extremely reliable.
Price: £ 22.52
Timing belt
1.6 & 1.8 models .. high quality timing belt
Price: £ 13.88
Cam Belt Tensioners
covers both 1.6 & 1.8 models
Price: £ 9.30 (tensioner)
Price: £ 13.00 (tensioner guide)
Alternator belt
we stock alternator belts to cover 89-97 & 98+ model
Price: £ 3.47 .. 1.6 .. 89-97
Power Assisted Steering Belt (P.A.S.)
we stock p.a.s. belt to cover models as stated
Price: £ 4.61 .. MK1 .. 1.6 & 1.8 model
PS MY CAR GOT AIR CONDITION!
Rocker Cover gasket
Price: £ 8.45 (both 1.6 or 1.8)
Water Pump
High quality, and carries a full 12 months warranty
Price .. 1.6 .. £ 27.67
Cubby box (U.K. Style)
this cubby box is required for conversion from Japanese to U K size radio installations and fits nicely under radio.MUST BE
FOR RADIO OF DIN SIZE.
Price .. £ 16.15
(sft) Tonneau Cover
This tonneau cover has been design and manufactured for sft .. easy to fit & remove (we are at present developing a cover if
roll bar is installed .. available shortly)
Price: £ 38.09
(sft) Tonneau Cover bag
This tonneau cover storage bag protects the cover when not in use
Price: £ 8.15
Window replacement kit
Are your windows moving slowly, or have stopped working altogether. This replacement kit will solve your problems. Comes
complete including motor, easy to fit, full instructions
Price .. £ 43.47
Brake Pads
We cover many manufacturers brake pads, and will always offer you the best deals possible in quality pads both front and
rear, and of cause are for standard road use.
Price (set) .. 1.6 front .. £ 11.64
Price (set) .. 1.6 rear .. £ 10.70
STARTER BUTTONS
This professional and universal starter button direct from Japan, fits neatly into the any dash panel position or cig lighter
if required by the driver. Complete with English translated installation instructions (MK1)
Price .. £ 29.80
Instrument Cover (dial cover)
This cover becomes very brittle after many years of constant weather change, so be very careful when removing, however,
normally damage is unavoidable.
Price .. £ 58.61 (mat black / V-Spec model)
Price .. £ (price on arrival) (Standard black)
1.6 MX-5 / Eunos Roadster workshop manual
Enthusiast's manual, easy to use! over 300 pages & over 1600 illustrations. Covers all pop-up headlight models. 1.6 (89-94)
also applies to later, but not MK2 model. Covers all 1.8 (93-97)
Price .. £ 12.99 (v.a.t. free)
Key Blanks
Mazda MX-5 / Eunos roadster key blanks
(if you are like me, we all misplace our keys now & again) keep a spare
Price .. £ 1.35
sftmx5 parts? Er de seriøse?
- kodvaag
1986 Master 820
X:
1990 Miata B pack + LSD
1991 Miata B pack + LSD
1998 MX-5 gull
1998 MX-5 sort
1992 MX-5 Rød
1991 MX-5 Brg HT
1991 Miata SE BRG
1986 Master 820
X:
1998 MX-5 gull
1998 MX-5 sort
1992 MX-5 Rød
1991 MX-5 Brg HT
1991 Miata SE BRG
Er fornøyd med sft jeg også..
Har fått et julekort jeg også
larsmx5 wrote:sftmx5parts er jeg veldig fornøyd med.. fikk til og med julekort fra dem i går! hehe...
- kodvaag
Høres bra ut, jeg får bare avvente svar på mail utpå nyåret når de er back in business...
1986 Master 820
X:
1998 MX-5 gull
1998 MX-5 sort
1992 MX-5 Rød
1991 MX-5 Brg HT
1991 Miata SE BRG
1986 Master 820
X:
1998 MX-5 gull
1998 MX-5 sort
1992 MX-5 Rød
1991 MX-5 Brg HT
1991 Miata SE BRG
