Du vet at du eier en NA når ...
Fant denne på nettet og må innrømme at, jo ..... :oops:
You know you're an NA Miata owner when...
~You have to explain to people that the car's faster if they're not in it, and then dodge the slap and accusations that you're calling them fat.
~You've spun out at least once, then quickly got going again, purposely spun 180 degrees the other way, and continued on as if you meant to spin the first time, only now your heart is about ready to explode because it's beating so damn fast.
~People insist it's FWD, you promptly prove them otherwise, and they get reeeeal quiet.
~You have to explain that your car is faster in turns than going straight.
~You think a 1.8 is a large displacement motor.
~You regularly use acronyms like AFM, CAS, NA, OTM, OPG, and YMMV.
~You know what HLA noise is.
~You get out the car when at a drive-through ATM.
~You find yourself driving much later into dusk before turning on your headlights to keep the aerodynamics clean.
~People have to ask you what kind of car you have--after you walk them around it.
~It's quicker to turn the engine back on to roll up the power windows, especially when cold.
~After buying your NA, you spend more time on Miata.net than you ever used to spend watching tv.
~You shop for rims and tires by weight.
~You know what it means to "add lightness".
~200-300hp is BIG horsepower.
~Your significant other understands that this is the other woman and still marries you.
~The only floor jack that fits is an expensive race jack.
~You repeatedly “searchâ€
HF-mx5T
Post by HF-mx5T »
kjenner igjen mange
EspenAndre
Medlemsnummer: 114
Post by EspenAndre »
Lest denne før, er maaange av dem som treffer bulls eye, kan man trygt si..!
:D :D
StianS
Re: Du vet at du eier en NA når ...
Post by StianS »
Rudolf wrote:~You think a 1.8 is a large displacement motor.
Denne skjønte jeg ikke - hva mener han med "You think"?? :?
StianS - medlem nr. 562
X '95 Miata 1.8 Montego Blue, Tan skinn, Hardtop, AC, CC, Torsen diff, ikke ABS,
EspenAndre
Medlemsnummer: 114
hehe en merkelig måte å være ironisk på sikkert :P
jepp lest den før eg også, ja og 1,8 er jo big blokka til mx5. :lol:
SweetMX5
Post by SweetMX5 »
haha kjenner meg igjen skikkelig og da :P og jeg har hatt mx5 i 2 mnd...
sant med det med fremmede er ikke fremmede hvis de har en mx5.. har prata med en del fordide har mx5 :P
O:'01 Yamaha R1 1000cc
O:'00 BMW 318CiA 1.8
X:'99 MX5 1.6 Kompressor
X:'97 MX5 1.6 Turbo
StianS
Post by StianS »
Prøvde vel på litt ironi selv... :oops:
Jeg følte meg truffet av det meste, ja - også det med 1.8/big block.
redrubin
Medlemsnummer: 52
Post by redrubin »
[quote="Rudolf"].
Har erstatet min rød -1990 modell med en MX-5 1996 modell.Vinrød rubinen(mer moden farge for en mer moden dame) skal passes på slik at jeg kan kjøre henne i 24 år, medlem siden 2000.
eito6260
Post by eito6260 »
Jeg kjenner meg også igjen i det meste. Jeg husker da jeg hadde 1991-modellen min, med 1.6-liters motor og 115 hester. Da var jeg litt misunnelig på de med BIG BLOCK, altså 1.8-liter. Nå har jeg 2-liter!! Det må være HEMI-utgaven. Jepp! 8)
Medl.nr. 393
x 91 mx5
2006 MX-5 NC 2.0 Sport, Eibach senkesett, Bilstein-dempere, LSD, 17" 205/45 R17, støttestag, xenon
StianS
Post by StianS »
eito6260 wrote:Nå har jeg 2-liter!! Det må være HEMI-utgaven. Jepp! 8)
Tilsvarer vel nesten V10'ern i Viper :twisted:
Geir_Bossum
Medlemsnummer: 4
Post by Geir_Bossum »
Spesielt disse:
~You wonder why in the heck people with other drop tops never have the tops down on days that its above freezing.
~You wonder why people brake before turns.
Hehehehe
2008 MX-5 Roadster Coupe, rød, 2.0l. Medlem nr 4 / 1999.
SweetMX5
Post by SweetMX5 »
eito6260 wrote:Jeg kjenner meg også igjen i det meste. Jeg husker da jeg hadde 1991-modellen min, med 1.6-liters motor og 115 hester. Da var jeg litt misunnelig på de med BIG BLOCK, altså 1.8-liter. Nå har jeg 2-liter!! Det må være HEMI-utgaven. Jepp! 8)
:P :P :P
X:'97 MX5 1.6 Turbo
